| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I just wanted to get some input on a good power steering setup for a 47-55 AD truck. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Keep everything tightened up to specifications Keep correct sized tires and correct air pressure Try to turn the wheels when the truck is moving
Just like any power steering I know of
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yup, I use armstrong power steering. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | whitedog, do a search for power steering and you'll probably get hours of reading. There are a couple good articles on installing it. There are a few pics in my photobucket that may help. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | speedway sells a fairly cheap power steering setup for your truck
1937 1/2 ton
