1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#817214 01/17/2012 10:21 PM
What size was the original exhaust pipe on a 292? I'm putting one from my great grandpa's '65 into my 1950. I've found some scrapped stainless pipe and was thinking of welding up my own system, but I need to know which pipe to get. Is there a size that would be "better" than stock? I know I don't want to go too big because I need back pressure. Thanks in advance!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
Depends on which exhaust manifold you have. There are two, and three bolt manifolds. The two bolt is 2", and the three bolt is 2.5" where the exhaust pipe bolts on. The three bolt bolt was more common in the bigger trucks.
Larry
I don't own a vehicle that isn't old enough to drink.
Riding in the Passing Lane
The light duty trucks had 2 in outlets that pointed back aways. The early models had 2 bolt flange & the later ones (about 71 on) used a 3 bolt but still had the same size outlet. The large trucks used a 3 bolt with 2 1/2 in. outlet. It pointed straight down. I would use 2 1/4 in. pipe reduced the the 2 in flange. You dont want back pressure. It is death to the ex. system on these engines. Use a free flow muffler.
1972 Chevy c10 Cheyenne Super
