| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81745 08/21/2007 12:06 AM | Joined: Oct 2006 Posts: 29 Junior Member | | Junior Member Joined: Oct 2006 Posts: 29 | Hi engine is a Chevy Inline 6 250 cid. Anyone know what the inside Dia. would be with Standard Bearings installed and everything torqued up. On the Main Caps & Piston Rod Journals? I think I need .001 oversize. But not sure? I mic the Crankshaft Mains at 2.2985 & Piston Rod Journals on the Crank are mic at 1.9992 to 1.9994. No out of round and no taper. Crankshaft is with-in spec. Just not sure if I should order .001 or standard bearings? Bearings are NOT cheap. | | |
#81746 08/21/2007 5:24 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Hello, This should help. The Mains bearing journal should be 2.2983-2.2993. Taper and out of round is just .0002. Crankshaft main bearing clearance is 0.0003-0.0029. End play is .002-.006. Rod bearing clearance is 0.0007-0.0027. Crankpin diameter is 1.928-2.000 Taper new wear 0.0003 +/_ 0.001. This is from a Clymer Chevy and GMC repair manual. Just had one rebuilt by a great machine shop. Can't wait to put it in m full size pick up. Bored .040, mild cam, 1.84 on the intakes, balanced, boss honed intake ports, decked block and milled head. Plus Moly rings and low dished pistons. Have an Offy 4bbl manifold with a new Holley 600 cfm carb, MSD and probably Fenton Headers with 3" Magnaflow exhaust for good flow but quiet with the large muffler. Should be a runner. I wish you well on your rebuild. I hope this info helps. Henry | | |
#81747 08/22/2007 2:50 PM | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | You are well with in stock size or range. Even if its a little loose, it won't hurt a thing. These 250's have plenty of oil pressure and volume to keep up with a slight worn engine. Joe | | |
#81748 08/22/2007 3:31 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Henery G....a question. Why did you chose such a large Holley for your engine? Thanks
#81749 08/22/2007 10:50 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | oldboy, any good source for a pulley for the 250/6 with a/c i need one for my 235/6 to install a/c on my truck. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#81750 08/23/2007 4:15 AM | Joined: Oct 2006 Posts: 29 Junior Member | | Junior Member Joined: Oct 2006 Posts: 29 | Thanks for all the info. WE b OLD As for your qestion. I will have many parts from a 1965 Chevy Truck 230 cid inline 6 engine. Will list All on Ebay. Its safer for seller & puchaser. And Yes I think I might have one in very good condition. | | |
