10 members (Gdads51, Jaison, frogfarmer, rfs56trk, Woogeroo, Hotrod Lincoln, JoeDude, Jon G, TexasA&M48Truck, dt235sd), 142 guests, and 3 robots.
Topics128,035
Posts1,055,528
Members48,425
#81655 08/18/2007 12:35 PM
As my 54/3100 nears completion?? i am thinking about putting cruise control on it. it is a stick shift, my mechanic was a little skeptical. thoughts on this. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#81656 08/18/2007 2:03 PM
I will have cruise control in my truck.
Right now I am leaning toward the one sold by Dakota Digital. Although I understand they relabel and sell one of the other popular aftermarket brands, so I'll probably get it from whoever really makes it, a little cheaper.
I want a cruise control system that needs no vacuum, because my truck doesn't suck, it's a diesel. I would also like to have the unit hidden under the dash, so my engine compartment looks simple and uncluttered.
Also has a manual, I figure I'll have the cruise control wired with a switch on the clutch, brake, and the neutral safety switch. That way if either peddle is pressed, or it's slipped in to neutral with out clutching, the cruise control kicks off.
I also figure I can make it work off of either engine speed or road speed, I have an electric sending unit in the trans for speedometer, and one that reads off the ring gear on the flywheel for the tach. Looks like I can have a switch between the two inputs going to the cruise control.
I am not yet convinced that the Dakota Digital is the best out there yet, so I'll do some more research before I buy one.
Anyone else considering or using aftermarket cruise control?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#81657 08/19/2007 5:46 AM
Cruise controls for stick shift rigs are still
available..I put one on a 66 3/4T with no problem and it worked just fine..most shops these days only want to work on the high $$$ new stuff..a lot of them don't have a clue about our old iron...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#81658 08/19/2007 5:52 AM
isn't that what the throttle cables for??? wink
GMC: Get More Cash...
1958 GMC
My Webshots photos
#81659 08/19/2007 6:20 AM
No, that is not what the throttle cable is for.
#81660 08/19/2007 1:39 PM
Just a throttle cable does not react to the load, say a hill.
What is needed is a way to vary the throttle as the load changes to achieve a constant speed.
A "road speed governor" so to speak.
Grigg
---All pictures---
#81661 08/22/2007 11:42 PM
It also helps to shut it down when your foot hits the brake. Otherwise be sure to take a roll of TP with you. grin
~Jim
#81662 08/24/2007 2:31 AM
Grigg that is why the cable will slide when you depress the peddle. You will find a lot of objections on this sight for using the throttle cable for a cruse. I've used mine for that purpos for years. I think that is what they were designed for. (Objections will appear, SHORTLEY). I, however have more insite than the objectors to push the throttle in before breaking. People will say it,s for starting, but if you know how the "B" carb works it pulls the throttle open when the carb is choked, so I don't think it was for starting. One old time farmer told me once he used his throttle in low gear in the field so he could get out of the truck and throw hay on the trailer. OK objectors your turn.
#81663 08/24/2007 3:39 AM
I am not going to object, but I will say I was not satisfied with my throttle cable as a cruise control.
The real subject of this thread is what are the "real" cruise control options out there?
Let's forget about the throttle cable as an option for now and continue thinking aftermarket cruise controll....
Grigg
---All pictures---
#81664 09/02/2007 1:36 AM
That Olde-Timey farmer is my new hero. I've heard a couple old guys talking about jacking up the rear, taking off one wheel, mounting a bare rim, and using the truck to drive old belt driven implements.
Sorry I'm off topic, but I just love people's creativity. Darwin awards, here we come.
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#81665 09/02/2007 2:35 AM
You would need one that has a speedometer cable adapter on a torque tube application, as the type that uses driveline sensors wouldn't work.
#81666 09/02/2007 2:40 AM
i have all new gauges from tpi and the cruise unit i am looking at is from Ron Francis wiring and it will work. the original query was it safe to put cruise on a stick shift vehicle. ron BTW i have an open driveline with a t-5 trans.
2017 Buick Encore
See more pix
#81667 09/02/2007 3:47 AM
I've been looking at an Audiovox CCS100 Universal unit for under a hundred bucks. Lot's of positive reviews for the vacuum controlled unit with a driveshaft sensor that you have to attach to that area. My setup makes good vacuum so I think I'll give it a shot. It's commonly used on a variety of bikes (That's scary) with an add-on vacuum can and if any of you have pros or cons I'd like to hear about them.
Obviously the Ron Francis units are a higher quality but for what they're asking for the Audiovox unit it's worth a try.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#81668 09/02/2007 5:47 AM
I didn't realize that you were asking if it was a good idea to put cruise control on a stick. I've had it on several stock stick shift cars and had no problems. The only difference with stick and automatic operations is that you have to reinitialize it when you shift unless you shift without using the clutch, then you might have trouble with it overreving in neutral while upshifting unless you accellerated beyond the set point in the lower gear.
#81669 09/05/2007 1:52 AM
My 96 1500 5 speed had factory cruise. Used it all the time even in town. Worked good even at 25 mph. Weeds
#81670 09/05/2007 5:59 AM
I've never owned anything but stick shift cars, and many of them had factory cruise. All you need is an extra switch for the clutch.
Paint & Body Shop moderator
#81671 09/05/2007 12:41 PM
Thanks all. ron
2017 Buick Encore
See more pix
#81672 09/07/2007 5:41 PM
Dave,
The guy I bought my Kawa from kept the Audiovox unit with him. He was going to put it in his car. He swore by it.
I have also seen one in a 1954 MG, at a car show, that had just completed a 10,000 mile road trip.
I think it's a basic, easily understood, piece of gear.
Go for it.
"Happiness equals reality minus expectations" - Tom Magliozzi
#81673 09/12/2007 1:11 PM
Apprentice
Apprentice
1 Offline
you know back when the Army Still used deuce it had a throttle and the army had a hard time convincing us it wasnt for cruise. seems it wokrs fine just be carefull as it dont disengage when you hit the brakes.
Aaron L. Springer
