| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Hi, I am trying to get the distributor out of my '46 216. Shop manual refers to a pin, retaining the gear to the shaft. Where is that mysterious pin?? Thanks.
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | the pin there talking about holds the distribitor gear to the distribitor shaft, you shouldn't have to remove that unless your taking the distribitor apart to rebush or something. if i remember on mine there is a bolt holding the distribitor inthe block somewhere around the bottom by the vacuum advance which comes out with the distribitor. hope this helps
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The distributor is held on only by the small bolt and advance plate at the base where it goes into the block. Some of these distributors are stuck due to oil and gunk buildup and require a fair amount of lubrication, a small pry bar and a twisting motion to get them out of the block.
The pin refers to a rolled pin in the drive gear on the end of the distributor shaft and once removed from the engine, is quite obvious.
Jeff | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The pin is in a hole thru the distributor shaft and its drive gear. It holds the gear to the shaft. Unless the pin is dislodged it should not prevent you from removing the distributor from the block.
Drew
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | is it a requirement to restate everything a new guy says on this forum. i think i answered the guys question right then two members come in and post the same response as me. whats the deal.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | DADS50, I see in the second picture you have an o-ring on the top groove. I have tried to do the same in the past but found it prevented the vacuum advance from twisting the distributor correctly. Did it work for you?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | No, thats a replacement distributor from NAPA and it came with the o-ring in that groove out the box.
that o-ring was a issue. Once I removed the o-ring the distributor worked fine.
I will add a note to that pic.
Thanks. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Thanks for the help! I assumed it should come right out, but even with a pry bar and a hammer it will not budge!! I have the oil pan off. Any ideas on how to get this darn thing out?? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Does the shaft turn to indicate that something is not jammed?
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So does this engine turn at all? Also I assume you removed the bolt holding the assembly down on the block. Can you turn the distributor? If you can then you want to turn it back and forth while pulling up gently. Don't use any pry bars. | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Well since the engine is not turning, the shaft is only moving a little tiny bit. Yes - the vaccum mechansim is loose. I removed all the "guts" from the distributor including governor weights etc. SO the distributor housing is turning freely now. Denny - I'd be happy to post a pic. Any particular angle etc?? Not a whole lot to see in my opion. | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Forgot to mention - I am able to pull it out by about half an inch. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | is the shaft coming up with the housing? if not the gears are stuck together. try turning the distributor shaft while pulling up.the shaft needs to turn indepently from the housing.it needs to turn as your pulling up to come out. mine was kind of stuck like that. might even help squirting a little squirrel [censored] around the shaft to loosen it up from distributor housing. then some down towards the dist. gear. once everything is loose just keep working it, soon or later it will pop out.
| | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Thanks Mo. Yes- the housing is completely lose (you can turn it as many times as you want!:). Shaft itself comes up about half an inch. Not easy to turn the shaft now since I removed all the "guts". I keep trying. | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | I took the outer housig of the oil pump off today and the gears slid out. Returned to the exterior of the engine was planning on continuing to work on the distributor...well,..it slid right out!
Sure glad it is out, but I would love to understand how all this happened! | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | I took the outer housig of the oil pump off today and the gears slid out. Returned to the exterior of the engine was planning on continuing to work on the distributor...well,..it slid right out!
