4 members (Wally / Montana, 59 fleet, Paul_WNC, Gdads51), 96 guests, and 1 robot.
Topics128,051
Posts1,055,734
#81633 08/18/2007 3:27 AM
Can I remove the side cover from the steering gear box while it is installed to inspect the inside with disturbing anything. The book looks like this will work.
49 chev 3100
#81634 08/18/2007 3:42 AM
No. The side cover has the adjuster for the backlash as an integral part of it. The end of the adjuster screw is engaged into a slot on the gear. In order to remove the cover, the locknut would have to be completely removed, then the adjuster screw tightened all of the way in and then some in order to remove the cover. Best would be to remove the box and disassemble on the bench if you really need to get into it.
Bill Burmeister
#81635 08/19/2007 5:45 AM
I have removed the cover the way Bill decribes it..
Its difficult to spin the screw to reinstall, but it can be done...
GMC: Get More Cash...
1958 GMC
My Webshots photos
