| | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81633 08/18/2007 3:27 AM | Joined: Jul 2007 Posts: 11 New Guy | | New Guy Joined: Jul 2007 Posts: 11 | Can I remove the side cover from the steering gear box while it is installed to inspect the inside with disturbing anything. The book looks like this will work.
49 chev 3100 | | |
#81634 08/18/2007 3:42 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. The side cover has the adjuster for the backlash as an integral part of it. The end of the adjuster screw is engaged into a slot on the gear. In order to remove the cover, the locknut would have to be completely removed, then the adjuster screw tightened all of the way in and then some in order to remove the cover. Best would be to remove the box and disassemble on the bench if you really need to get into it.
Bill Burmeister | | |
#81635 08/19/2007 5:45 AM | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I have removed the cover the way Bill decribes it.. Its difficult to spin the screw to reinstall, but it can be done... | | |
