| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | I need to replace the windshield regulator on my 37 half-ton. Will any other years be the same? OR where can I get the gears repaired or replaced on this one. Thanks
Bill garvey
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bill, I think there is a tech tip on rebuilding them. It can be done as those little suckers are getting expensive. I would think the 36-39 would work but don't quote me on that. Hopefully someone will chime in over the weekend for sure.
EDIT: or you could just check out one of the vendors like JimCArter and see what years they list the same replacement for.
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Alvin is correct - a couple of the vendors offer a rebuilt regulator, but they are very expensive. And your old unit can save some money if it is deemed "rebuildable" by that vendor. I have gone thru several of these units. You need a good housing (axle holes not real sloppy),and decent worm and worm gear. The small brass wear plate will need replacing for sure. And most important, the tongue has to be in good shape. If you feel froggy - read thru tech tip on this and see what you feel safe messing with. They do come apart relatively easy. Good luck! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...on the worn "axle holes" a bushing can be obtained, probably from Ace Hardware. That in itself is a lot of the problem.
...I wasn't going to say but I have a "rebuild" kit but its a "one off" and a present to me. A fellow bolter made his kit but can't do it for the masses. I sure wish he could as it's save a lot of guys some nice $$. | | |
