Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#816054 01/13/2012 5:38 PM
Changing points. The new set from NAPA came with an extra unattached curved silver metal spring. Old points didn't have this extra spring. Is it necessary?? Where would it go? Thanks
Here is a set with one spring, I think.
All the ones that I have used on 216/235/261 engines have a thin contact-spring and a thicker spring (two pieces) that went around it. It looks like one-piece contact/spring points-units are now available.
Here's one with two "springs".
Here is one for a 1959 235 at Rockauto.com.
Can you post a photo of what you have?
What is your NAPA part number?
Thanks for the reply Gabster.The contact set base is just like the one you showed (which is like the one I took out) with one spring but it came with the extra spring to clip in like the second pic you showed. NAPA part # is CS763P Should both be used?
The NAPA website only shows one spring for that set of points.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=ECHCS763P_0218330823
Maybe someone else will post some helpful information?
I'd use the parts that came in the box.
The spring spoons the brass strap.
If you do not use the extra spring the brass strap will not put enough tension on the points and they will float.
My Blog
Like dave says the brass is just for elec contact the silver peice is the spring use both.
