| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | What is the conensus for putting the black rubber mat in rear of the 36 suburban..or NOT...wood will look pretty when finished..and then cover? But correctly is was covered with rubber mat? Also is Steele the best place for floor mat and roof vinyl...or is there another source? thanks guyd...Bruce | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I know on the later AD suburbans the floor was covered in a grooved battleship linoleum or some similar material. Did the '36 come with a rubber mat over wood?
Kurt | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Yes..Kurt..the rubber mat was there and had a thin pattern line on it..so will get nice oak but will end up covering it with blk mat. bruce | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Weeds, that is spectacular! Is that cherry?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
