1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
#808378 12/19/2011 7:06 PM
What is the conensus for putting the black rubber mat in rear of the 36 suburban..or NOT...wood will look pretty when finished..and then cover? But correctly is was covered with rubber mat? Also is Steele the best place for floor mat and roof vinyl...or is there another source? thanks guyd...Bruce
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
I know on the later AD suburbans the floor was covered in a grooved battleship linoleum or some similar material. Did the '36 come with a rubber mat over wood?
Kurt
Yes..Kurt..the rubber mat was there and had a thin pattern line on it..so will get nice oak but will end up covering it with blk mat. bruce
More pix on Flickr
I think the wood looks better. If you are going strictly stock then cover up the wood. It seems nobody can find the "correct" linoleum, mat, whatever anyway so I elected to let the wood show. My .02.
https://picasaweb.google.com/lh/photo/SLTs90Uwu5oFASH2vasaSNMTjNZETYmyPJy0liipFm0?feat=directlink
Weeds
Weeds, that is spectacular! Is that cherry?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
