2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#814951 01/09/2012 11:39 PM
Does anyone know if there's a difference in a 94 T-5 and the older ones? I have a 94 T-5 and was hoping it will work in my 1940 1/2 ton with a 235 and an adapter. Thanks 40Rat
40rat #815015 01/10/2012 3:11 AM
Sometime around 1985 (1987?) they went from mechanical to electronic speedometers. Only the older ones have a cable drive.
Check some of the tech tips here, there are ways of doing it without an adapter.
Highflyer #815099 01/10/2012 12:48 PM
One more question and I'll leave you guys alone. How would the 235 motor, the T-5 transmission, and the rear end out of the 94 S-10 work in my 1/2 ton 1940 Chevy? 40Rat
40rat #815110 01/10/2012 2:49 PM
Should all work great......I would make sure the rear end ratio is about 3:55 or more (numerically) and what the gearing is in the T-5 ?
helilog56 #815407 01/11/2012 1:24 PM
The T-5 OD ratios are all over the place from .72 to .93! You must KNOW which T-5 you have. You will also need the S-10 shifter to keep the shifter from coming out under the seat!
best wishes,
Les
