4 members (Hanks custodian, 3800GUY, Bill Hanlon, Ponchogl), 97 guests, and 1 robot.
Topics128,113
Posts1,056,580
Members48,448
#814637 01/09/2012 1:33 AM
mo
Offline
new to stovebolt. rodding out a 51 chevy 3100. will have a clean and smooth boxed frame. mustand ii front end tci rear leaf with narrowed 9 inch ford posi with 370 gears. 350 4 bolt hopefully around 450hp and a 700r4. discs all around to stop. dont know which color yet but it will be shiny and deep with some minimal chrome. thinking a second series dash with some tricked out features such as vacuum doors over radio and dash knobs. just looking for a very clean show and drive truck. thinking it will take ten years to build but i think it will be worth it.
MO's 1951 chevy 3100 resto mod project
Leo Online: Content
Moderator
Moderator
Welcome mo, quite a plan you have. I hope you can do most of it yourself. If you have any questions, just ask.
Leo
just 15 minutes EVERYDAY will soon add up. It may take 10 years but I think you'll get it done before then. I spent "only" 5 years on each of my projects but probably should have taken 10 !!
mo
Offline
thanks for the support. hopefully putting frame on a frame rack this weekend just to make sure everything is where it should be. noticed one front frame horn is off a little so that the next step. could probably straighten it out at home but its just easier on a rack. that way i can tie it down and jack or pull where needed. other than that were almost done smoothing and filling the 200 plus extra holes. then i can start the mockup of the frame.(ie the suspension, brakes,engine and trans) anybody ever ran brake lines inside a boxed frame? anyway later mo
Hi Mo,welcome from Scotland.
Sounds like you have a plan,10 years sounds a lot but then I realised i've got 7 in mine!
Re: The brake lines,I understand why you want to do it and I think it's do-able.
Personally I prefer to be able to see the condition of critical parts.Especially brake components.
I would forego form over function in this instance.JMO.
Just a heads up Mo,as not to incur the wrath of the Mods,we should keep these type of Q&A's to the relative forums.
See you around.
Jock.
More pix on Flickr.
Hello from Indiana- good luck on your project-take it on as you feel like it so it'll stay a fun build
Ken
1946 Chevrolet 2-Ton
More pix of the '46 on Photobucket
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
1955 DeSoto Fireflite
I'm pullin for ya. We're all in this together -- Red Green
