2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81438 08/14/2007 2:14 AM | Joined: Mar 2000 Posts: 1,180 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,180 | I've finally gotten around to doing some research on my truck. A while ago I picked up a 3.73 limited slip rear (disk brakes) for it and hooked it up to a T-5 tranny that I got for not too much money. Driving the truck was enjoyable, but I never got out on the road to really push it. Yesterday I finally found a place on the web that told me exactly what gearing I have in the tranny. T-5 gear ratios Turns out my T-5 is from a 83 Firebird V6 2.8L car. The gears are 3.50, 2.14, 1.39, 1.1, 0.78. So, I went to one of the online RPM calculators and figured out that my top speed at 3000RPM was 46MPH???? Another one said it was 71MPH. Anybody know of a site that accurately determines speed based upon rpms and gearing? | | |
#81439 08/14/2007 2:46 AM | Joined: Mar 2000 Posts: 1,180 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,180 | Never mind. I figured out what I was doing wrong. My tire size is 205/70/15, so my diameter is 26.29 inches. I should run 65 at about 2500 RPMS. | | |
#81440 08/14/2007 2:52 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Aww, nuts. And I was gonna run inside and get the book (Auto Math, exellent book! ) to get the formula for ya! BTW, I figured mine once after a run to see how it did wound up a bit, ran about 3300 rpm, speedo said 80-ish. Ran the #s, came out that I was actually doing 109!!!!  Needless to say, I haven't done that again!
Bill Burmeister | | |
#81441 08/14/2007 3:19 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | |
#81442 08/14/2007 3:24 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i use, www.randysringandpinion.com. ron BTW i run a nova rearend with a 2.73. a little low in town in first.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#81443 08/14/2007 2:18 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You might try: http://csgnetwork.com/multirpmcalc.html I like the bottom calculator as it let's you dial in your exact values. According to this calculator, you should be turning 2417 rpms@65mph. Just another tool for your toolbox. IMHO you've got a pretty sweet setup....the 3.50 1st gear is going to let you stay in first a little longer than the S10 3.76 1st gear and the .78 is a bit lower than the S10 .72. You'll be able to zip around town in 4th gear and still stay within your torque band. I'm running a 3.42 with a .72 and a 29" tall tire and 2000 rpm's at 65-70mph (with corrected speedometer). I can drop down to 45 mph in 5th and accelerate back up with traffic without a downshift. The cruise at 70 mph is effortless, vacuum gauge hovers at 14-16" at cruise and 20" at idle. There's plenty left with my tweaked 235 but I'm most comfortable at the 65-70 as I'm running the stock straight axle. The aero on these old trucks wasn't really designed for high speeds, and the air noise in the cab at 75-80 is annoying. Your setup should be a real hoot to drive!!! Have fun!!! Dave | | |
#81444 08/16/2007 4:07 AM | Joined: Mar 2000 Posts: 1,180 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,180 | I'm running the stock front axle as well. Don't see any reason to change. I replaced the front springs, which were broken, with a set of Patrick's monoleafs. They cost me no more than replacement spring would have, and they lowered the front end 4" and stiffened it up. With hydraulic shocks, it rides real nice. | | |
#81445 08/16/2007 2:57 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=010819#000014 && http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=23;t=000654;p=1#000007
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
