6 members (farmallb, ChevyBlue, 2-Ton, carbking, Hotrod Lincoln, tclederman), 144 guests, and 1 robot.
Topics128,089
Posts1,055,991
Members48,430
#813709 01/06/2012 2:16 AM
I,m ready to install the front fenders on my 51 3100. the 49-51 truck shop manual discusses removing the front clip in one piece, it also discusses removing just a fender. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1110.htm
my question to those who have done this is should I put the front clip on one piece at a time or assemble it on the floor and install it in one piece??
here is where I am at http://i1126.photobucket.com/albums/l611/digger3700/DSCF2230.jpg
Thanks for any help
Hi John
I think every case is a little different depending on how much replacement or
re-pop sheet metal is used in putting the truck back together.
In my case (51 panel), I have all Chinese fenders & grille attached to the original stock radiator support and stock inner fenders (stock hood too).
I have put it all back together VERY carefully after painting ( did not fully attach
the front clip stuff before paint due to a scheduling issue, big mistake)
THe grille will not align properly with the core support or the inner fenders; and the fenders will not align with the grille.
Although I got it all "close" I am about to take it all apart, drill BIG holes in all the Chinese stuff and assemble it all off the truck; then attach the whole front clip
as the shop manual suggests.
It is a pain to try to attach the fenders one at a time; esp, after paint.
squire
Y
Y Offline
Like Squire says, alot depends on what you've got to work with. From your pic, looks like you have all original sheet metal? I would just say that it's easier to work on something out in the open, than while hanging off the truck. I would only suggest putting all nuts and bolts togeather finger tight and once you've got the clip back on the truck, you can adjust, align, and tighten them up.
Thanks Squire and Yakimabowtie.Just needed a nudge to decide which way was best.
Nice truck Digg
Working alone I install mine a piece at a time.
very enjoyable... it starts to look like a truck again.
steps 1-11 here
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0103.htm
will help with front end alignment.
Did you remove your cab?
fender brace dimensions here
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1105.htm
I ended up needing shims under the rad support.
Very good advise given above to leave all fastenser loose.
Do you have any more pics?
Good Luck
Nice truck, hope mine looks that good. I'm just finishing up a mustamg II front suspension. Not ready yet to start re-hanging the sheet metal though.
Joe
I took your advice and am going to assemble the parts on the floor, even with original sheet metal I had to work at getting some of the holes lined up
http://i1126.photobucket.com/albums/l611/digger3700/FRONT%20CLIP/DSCF2295.jpg
Looks great!
Keep us in the loop.... I'll be doin' the same drill on my panel in
a couple of weeks
squire
Originally Posted by Squire
Looks great!
a couple of weeks
squire
Put the front fenders and hood on today, 2 of us put the fender assembly on in 5 minutes, 4 of us to put the hood on in about the same time, everything is just finger tight and now needs to be adjusted. all in all it went way easier that I had anticipated .
http://i1126.photobucket.com/albums/l611/digger3700/HOOD/DSCF2297.jpg
http://i1126.photobucket.com/albums/l611/digger3700/HOOD/DSCF2305.jpg
http://i1126.photobucket.com/albums/l611/digger3700/HOOD/DSCF2306.jpg
