| | | Forums66 Topics128,257 Posts1,058,010 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Hi John
I think every case is a little different depending on how much replacement or re-pop sheet metal is used in putting the truck back together.
In my case (51 panel), I have all Chinese fenders & grille attached to the original stock radiator support and stock inner fenders (stock hood too).
I have put it all back together VERY carefully after painting ( did not fully attach the front clip stuff before paint due to a scheduling issue, big mistake)
THe grille will not align properly with the core support or the inner fenders; and the fenders will not align with the grille.
Although I got it all "close" I am about to take it all apart, drill BIG holes in all the Chinese stuff and assemble it all off the truck; then attach the whole front clip as the shop manual suggests. It is a pain to try to attach the fenders one at a time; esp, after paint. squire | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Like Squire says, alot depends on what you've got to work with. From your pic, looks like you have all original sheet metal? I would just say that it's easier to work on something out in the open, than while hanging off the truck. I would only suggest putting all nuts and bolts togeather finger tight and once you've got the clip back on the truck, you can adjust, align, and tighten them up. | | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | Thanks Squire and Yakimabowtie.Just needed a nudge to decide which way was best.
| | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Nice truck, hope mine looks that good. I'm just finishing up a mustamg II front suspension. Not ready yet to start re-hanging the sheet metal though.
Joe | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Looks great!
Keep us in the loop.... I'll be doin' the same drill on my panel in a couple of weeks
squire
