4 members (Fannin, Phak1, TUTS 59, 1 invisible),
180
Mod | | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 6 New Guy | | New Guy Joined: Dec 2008 Posts: 6 | Hey folks I could use a little help. I picked up my 62 a few years ago and it was not complete so I am a bit confused about the heater situation.
I have a recirculating type heater core and the controls on the dash are two levers. One for the fan ( I assume controls speed) and the other lever controls the flapper in the heater box ( I assume to divert heat to the defroster or to the floor area).
My question is: In looking at LMC is shows heater control valves for a 62. Would this be for the deluxe heaters. I don't remember having found any of this hardware when the truck came apart. The heater core connections run through the firewall directly to the intake and to the water pump connection.
Without a control valve the heater would run continuously??? Am I mising something??? HELP!!!Thanks!!!! | | | | | Joined: Nov 2011 Posts: 26 New Guy | | New Guy Joined: Nov 2011 Posts: 26 | Hey ChevyD23 that is a good question I have the same two levers in mine as well. When I purchased it it did not have any kind of control in side or outside in one of the hoses to the engine. I do know that my type of heater was a dealer supplied one after purchase of the vehical. I guess to control the heated water or coolant one would have to put a control valve in one of the lines to stop the fluid from reaching the heater core. I have seen such valve on newer vehicals. Well some time in the future I'll find one and install it. Do you have any photo's of your truck? My 63' | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | My understanding is that deluxe heater has for levers. Two lever is standard | | | | | Joined: Dec 2008 Posts: 6 New Guy | | New Guy Joined: Dec 2008 Posts: 6 | Thanks Hambone, but with only two levers are there no heater control valves? | | | | | Joined: Dec 2008 Posts: 6 New Guy | | New Guy Joined: Dec 2008 Posts: 6 | Markeb, Wow. All the info I could have ever wanted. Thanks for the help. I will most likely do the manual shutoff as the truck will most likely be a fair weather vehicle for fun. David | | |
