9 members (TUTS 59, cmayna, TooMany2count, Hotrod Lincoln, Otto Skorzeny, TexasJim50, Jay R, Forty9, 1 invisible),
92
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I just had my tow truck Master Cylinder fail while pulling into the garage and I want to replace it with a Dual-Circuit type. So the question is, have any of you upgraded your single pot MC to a Dual-Circuit MC and then connected a Hydrovac to each circuit? I'm told this should work and that some British cars were made that way. My truck has the 1-1/2" bore MC and the largest Dual-Circuit MC I have found is 1-5/16" bore (1970's Chevy 1-ton). Any reason why this won't work? Thanks, Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It will work.
I'd go look at some 70's Ford medium duty trucks as well as many import cab over trucks, I've seen modern versions of what you describe on each, and others too I'm sure. The remote mount boosters could be a new off the shelf item if you like, I've seen them in the brake parts catalog at NAPA.
Grigg | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Grigg, The reason I was thinking of the remote boosters is due to fitment/lack of space to put a modern booster at the MC. I could add a Power Steering pump to the 350sbc and go Hydroboost if you think that would be better. I need to see if they have them in 1-1/2" bore. I'm thinking if I keep the same bore I'll have the same peddal travel...thoughts? Mike B  | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I asked this same question quite some time back. There are dual hydrovac models available that look like two smaller canisters attached back to back with the brake line fittings on either end.
I can't find it via the search feature. Maybe you'll have better luck.
Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Grigg, ...I could add a Power Steering pump to the 350sbc and go Hydroboost if you think that would be better. I need to see if they have them in 1-1/2" bore. I'm thinking if I keep the same bore I'll have the same peddal travel...thoughts? Mike B  That would be better for sure. May or may not be any cheaper, and yes you can get a large enough MC, I'm running 1-5/8" on my truck. Your most economical method of gathering parts is the salvage yard, and new at NAPa is not so bad either. I'd skip the aftermarket vendors if you don't need their tech assistance. If you also want power steering or already have it then it's a no-brainer, use the hydroboost. Without a PS gear you can still run bydroboost but you'll need to braze a high pressure return fitting to the pump reservoir (-6 AN/JIC or 3/8" inverted flare). Excellent info on hydroboosters and a good resource. http://www.hydratechbraking.com/FAQ.htmlNote this one though... Q: Can I install this kit if my car does not have power steering?
A: You must have power steering installed and operational in your vehicle in order for this system to operate. If you have installed an aftermarket power steering conversion kit please contact us prior to ordering so that we can equip your kit with the proper length hoses and fittings. Last time I researched this it wasn't a problem to use a PS pump solely for a hydrobooster. In fact that's the plan for my 1 ton, use a small (model TC I think it's called) PS pump so it'll fit nice and clean on the little Detroit. Grigg | | | | | Joined: Dec 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 64 | hey grigg, my neighbor has an 82 ford b600 school bus with a gas v8. it has a dedicated ps pump for the hydroboost, and another larger one for the steering... just an fyi
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
| | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | I would think that the 1 5/16 bore would be ok. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | hey grigg, my neighbor has an 82 ford b600 school bus with a gas v8. it has a dedicated ps pump for the hydroboost, and another larger one for the steering... just an fyi Thanks, I'll keep an eye out just to see one. Have no doubts about using a new TC pump though. Grigg | | |
