7 members (bobwithm, ESum, Steelonsteel, Bill Hanlon, Gdads51, TUTS 59, 1 invisible), 130 guests, and 3 robots.
Topics128,088
Posts1,056,124
Members48,435
#812690 01/03/2012 3:11 AM
Does anyone know if there would be a problem if I move the differential 3 " forward on my half ton so I can center the wheel in the wheel well opening.
Not sure what your doing.....do you now have open driveshaft?
I moved my rear end on the 52 panel to center it up but I'm running open drive line (put a 56 pumpkin in original housing) and just cut my drivesshaft to length. No problems with the wheelbase.
Have an open drive shaft. Every thing measures out the rear end is in the right place 115" wheelbase. How did you get the link on your message for photobucket.
