6 members (Shade Baby, Patharr, Ponchogl, TrknGMC, Bill Hanlon, 1 invisible), 98 guests, and 0 robots.
Topics128,119
Posts1,056,311
Members48,439
Hello. I'm rebuilding my carburetor (Zenith), and I'm wondering if I should install the new gaskets dry, or should I use Permatex or some other sort of gasket treatment?
Riding in the Passing Lane
No! do not put any thing on them .
1972 Chevy c10 Cheyenne Super
Carburetion specialist
I am unaware of any carburetor gasket on any carburetor on which gasket treatment should be used.
Some of the original gaskets were to the soaked in denatured alcohol prior to use, but never sealer of any kind.
Jon.
The Carburetor Shop
DEFINATELY NO !...do not put any type of sealer on the gaskets ...
1952 Chevy Shortbed
Photos in Photobucket
AMEN! DRY!!!!!!!!!!
Like everybody says, no sealer, but also FLAT and CLEAN. Do not over tighten the screws. Most leaks are the result of someone over tightening the screws. You can sometimes true up warped surfaces by laying a large pc. of fine grit sandpaper on a hard flat surface (like glass) and rubbing the gasket surface on the carb around in circles on the sandpapper. This meathod lets you see what is flat and what is not. Of coarse this only works if the carb does not have anything which sticks up past the gasket surface. Then clean the surface with a little solvent and screw together, but don't over tighten.
Junior Member
Junior Member
And Whatever you do. Do not stick a screw driver or putty knife in a gap and try to pry the Carb apart. You will marr the aluminum and it will leak at that spot.
Old Fart I have done exactly what you are talking about before it is very Effective for trueing up the surface.
SuperDuke, ya gonna let us in on your secret for spliting the carb halves apart if you don't wedge any thing between them?
Here's what I do if I have a really tough one that simply refuses to seperate. I've used blocks of wood that I cut to the proper heigth and brace one end on a base plate that I bolt the throttle body down to and then use a pry bar of sorts between the upper end and a pry point on the air horn. I try to use a piece of aluminum between the pry bar and the zinc when ever possable.
Denny G
Denny G
Sandwich, IL
Denny,
I just pull off the screws and put it in the freezer for a while, and then pull it out and give it a slight twist and tap. Has worked every time so far.
Paint & Body Shop moderator
Junior Member
Junior Member
A freezer???? Dude, you are my hero! Thats ingenious!
Up till now I have always tried to simply pull with my hands while tapping on the base with a softblow hammer.
But the freezer is up next!
Wife- Why does the ice smell like gasoline?
That makes way too much sense! :hammering: :hammering:
Don
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
Zip lock bags were invented to keep the ice from tasting like gasoline :p grin
Jon.
The Carburetor Shop
