0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
I'm thinking about dumping my Roch B for the 2 barrel Tom has on his site. What has anyones experience been with this carb. It will be going on a stock 55' 235. Thanks
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Good setup, I have been using them for 3 years. Runs smooth and good power.
Pat
pf
There's one down side to the use of the H/W carbs. If you're a tinkerer, your fun will be limited. There's the choke to hook up, then the fuel line and throttle linkage to fabricate. And, of course, an air cleaner to fit. But then you're done. It's just going to sit there and work. No leaks, no bog or hesitation to sort out. No periodic readjustment. You'll have to find some other part of the truck to be frustrated at. <grin>
regards,
Leon
Works great,good mileage improvement over the old rodchester. However I found that I didn't seem to have as much low end power as with the old carb. Otherwise I like it.
Tommy
59 apache 1/2t
261 short stepside
I'm running a pair on my 261 and they are great. Tom helped me with swapping to larger jets now she runs strong. I got Tom's air cleaner and adapter.
1946 1/2-Ton Chevy
