0 members (), 200 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#812358 01/02/2012 2:34 AM
On a 1963 230 engine does the vacuum advance rotate the distributor cap similar to a 235 . If it does mine must not be working as I see no movement with throttle changes. Thanks
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
No it does not rotate the cap, its all internal. If you pull the cap off, you should see the center plate rotate clockwise as you apply vacuum to the advance unit. While you under the cap, give the rotor a turn to make sure the springs and weights are free. It should snap back as you turn it.
Joe
Joe H #812532 01/02/2012 6:15 PM
Thanks Joe
I was trying to see if the flat bar that is at the back of the vacuum advance unit moved in and out . I am looking at replacing this distributor with an hei unit if I have to start replacing parts.
Riding in the Passing Lane
It does not rotate the dist like the old Stovebolts did but you can see the arm move with the engine running.
1972 Chevy c10 Cheyenne Super
