2 members (Gdads51, wilbur53),
110
7
Mod | | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Thank you for sharing, this one is just like my brother's. You'll make a lot of friends here , probably see you around the Big Bolt forum
Ken | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | I'm not sure yet if the majority of people here are purists or not, but I've been drooling over dropping a 6v53 detroit into this truck. There is a guy over on 4btswaps that has done this exact swap on his c60.
However, im trying to not get buried like with every other car ive restored. Take it slow and do what needs to be done first. Rust repair, new tires and the 292 come first. That way I can still use it as I repair things. After paint, new rubber seals and glass and a new deck, ill get into a detroit. Ive always thought I was in the minority liking these trucks, but its clear Im not and am glad to be here. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Oldtek88, Welcone to the Stovebolt  You're not alone, but be aware...this is a sickness with no cure...lol  Mike B  | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Nice truck !!! This is propably exactly how my truck looked like before someone made the bed a bit longer.
My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Welcome to the bolt! You have a nice looking truck and yes it is a sickness with no cure, I know this as I have been working on my 56 for 7 years now. Money and mind changes are big time consumers. I however have also picked up a few more big bolt projects and I am sure I am A. D. D. as I can not focus on one at a time. LOL | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Wow guys! great looking trucks! I don't know about anyone else here, but I dig the surface rust, dents and faded paint! Just shows character. I keep thinking about painting mine, but just can't bring myself to remove the battle scars and personality that has taken 60 years to accumulate! http://i1204.photobucket.com/albums/bb406/michelleturk/IMG_5403.jpg | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | I know what you mean. I can tell you where every dent on my truck came from. Its a little bit of history thats just part of it. However, I need to fix the rust, and doing that means sanding the patina off so im going to have to paint it. | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | quick question. what kind of transmission would be in my truck? its a 5 speed and original to the truck. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | oldtek88, Your transmission would be the optional "New Process" 5-speed. The 60 Series trucks had the SM-420 4-speed as standard equipment. Mike B  | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | what NP would it be? like an np540? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Sorry I can't confirm the model number...I've never seen it listed in any of my literature. Mike B  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | '59 supplement shows the 5 speed as a Clark 267VBill | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | Thats fantastic! Thank you. | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | Also, after really looking at the truck today I noticed I had the rims that come apart in the middle. These are the original wheels that came on the truck and have only been taken apart once. (the truck is only on its second set of tires since my grandfather bought it new. The tag for the tires is in the glovebox). Are they acceptable to use? Or should I look for new wheels? http://i89.photobucket.com/albums/k231/vwluver74/IMAG0273.jpg | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | red58, The Clark Transmissions were only used on the 70 & 80 Series trucks. The 60 Series (which oldtek88 has) used the New Process and the 90 & 100's used the Spicer transmissions. oldtek88, Those rims are the "widow makers" which should be replaced with either a lock ring 20" tube type wheel or a 22.5" tubeless wheel. Happy New Year! Mike B  | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The easy to figure out if it is a Clark or a New Process is by the shift pattern. A Clark will have 1st away from the driver and toward the seat and reverse away from the driver and toward the dash. A New Process will have 1st toward the driver toward the dash and 2nd right next to it. Also a New Process has 4 positions toward the dash and only 2 toward the seat while a Clark is 3 and 3.
As for the wheels, it sounds like you have the Firestone RH5° which are the dangerous kind. | | | | | Joined: Dec 2011 Posts: 30 New Guy | | New Guy Joined: Dec 2011 Posts: 30 | | | |
