4 members (TUTS 59, dt235sd, cmayna, 1 invisible),
70
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | Hi Guys, pizza man here. Any thoughts on getting my truck to stop better, disk, changing axle etc.. i really need to stop better. Truck weighs 12k lbs now with pizza equipment. Thanks in advance. jack oldworldpizzatruck.com | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Its not going to put you thru the windshield when you tap the brakes you have to drive acording to the load and road conditions, are the brake shoes properly adjusted,and is the hydro vac working, if the truck has seen little use and has not been driven much lately there is a good chance that the a wheel cylinder has stuck, this greatly reduces your stopping power, there is nothing wrong with a stock brake set up when done correctly, I went thru a 23 2 ton Chev with new parts and pieces and it will throw you against the steering wheel and it has a overhead moving van body on it. | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | It does not have a hydro vac on it brakes are adjusted but the main problem is going down long hills and having to stop fast. The brakes getted heated on the hills. I drive it regularly as it is my business. The truck ways about 12300 lbs with all that i added to the body.. I don't think hydro will help heating of brakes do you? That's why i was think of disk.. Thanks, Jack | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | surprised it doesn't have the hydrovac, was an RPO but pretty common original equipment and it will help, along with downshifting on hills and not riding the brakes ... my 46 with hydrovac had better brakes than any other lighter old truck I've had, if you're pushing that rig on the highway you should get the hydrovac Bill | | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | I would think the truck is rated for around 15000 lbs, so the factory brakes should be adequit. Are your hoses in good shape? maybe try dot4 fluid. disc brakes will actually build up more heat than a drum brake set up. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I would think that 46 had a hydro vac, some one with knowledge about that vintage should chime in here, but it sounds like too much downhill speed to start with as in being in too high of gear and riding the brakes, rule of thumb is go down the hill in the gear you went up. | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | I grew up in the trucking business, so i know how to drive trailers down to something like this, the problem going down hill if you have a 1mile to a couple mile hill is that you either brake on and off or downshift but then you will start over revving.. | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | It is a daily driver for me in the summer, highway, streets, hills whatever. I mean if someone pulled out in front of me and i was going 40 mph or they stopped short, this truck is not stopping. | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | where can i get a hydrovac for it and will it help that much... | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The hydrovac will NOT help you stop better. It only makes the pressure required of your legs, less.
I would do a preliminary check of all moving parts in the brake system and make sure everything is adjusted accordingly. As mentioned above, a stock system is more than adequate for hauling the weight you mention.
The huck brake system does require normal adjusting of each brake shoe seperately if the truck is used as commonly as you say.
Is this system stock?
Jeff | | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Here is the unit that I got from ABS Power Brake. http://inlinethumb30.webshots.com/48989/2701798080096773078S600x600Q85.jpghttp://inlinethumb21.webshots.com/47572/2320770950096773078S600x600Q85.jpgI have yet to put it to use as the truck that it is in is not finished yet but it was an easy bolt in as it mounts to the frame using the holes for the stock master cylinder and uses the stock pedal. In the picture it is shown with a hydro-booster and a dual circuit master cylinder. ABS supplied this entire unit I let them know what type and size brakes and the diameter of the wheel cylinders and that there were two per brake and they ensured that I would have the right master for the job. I opted to use a remote reservoir so it could be mounted for better access. Hope that this helps I think that the mount it self would be pretty easy to build yourself but must say I was very happy with the help and service I got from ABS.
| | | | | Joined: Dec 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 54 | ABS?, and how much was the whole setup.. Thanks, Jack | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I bought it in 2007 and don't remember I think it was around $600 but it could have been half that. Here it is on their web site showen here with a pedal assebly http://abspowerbrake.com/maincatalog_frameset021.html | | |
