1 members (Otto Skorzeny), 102 guests, and 3 robots.
Topics128,114
Posts1,056,605
Members48,450
Hi Guys I am thinking about having the engine rebuilt in my 54 one ton chevy truck any thing i should think about? It has 80.000 miles on original engine and shuld s guy have the trans gone thur at the same time? Thanks Tonyhttp://i1193.photobucket.com/albums/aa359/crockbuyer/006-1.jpg
What size engine 235 or 261 ? Have you looked up the engine cast # to verify what year engine ?
1954 chevy one ton Pics
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
no but will do nice work on your truck! I was told to rebuild the motor it would not hold up to high speeds 65 70 mph I was thinking about puting on Langton cast iron intake and headers but will see waht the thoughts on rebuild first Tony
"I was told to rebuild the motor it would not hold up to high speeds 65 70 mph . . . "
With standard equipment in your one-ton, the engine would be turning about 3,645 RPM at 65 MPH (3,925 RPM at 70 MPH).
That would even strain a carefully rebuilt 1954 235 engine.
Before you rebuild your motor, have you checked the oil pressure and the compression?
If you plan on driving it at 65-70 MPH, will you be changing the transmission/rear-end?
If you are planning on driving it that fast, you may want to look into suspension and brake upgrades as well.
thanks for all the tips on rebuild
I have the original 216 in my 50 1 ton.
Oddly enough it has been great except for the blown head gasket and the 8" crack in the block...
Things I'd suggest.
If you are going to drive it in modern day traffic.
Go through the whole brake system.
Change the gearing in the rear end. I put 4.10 gears in mine and the difference between that and the original 5.14 gears is awesome. I get decent fuel mileage and i can talk to passengers without screaming.
Currently I'm building a slightly tuned 261 with dual carbs and Fenton headers a 254 cam polished and balanced rods and pistons and a rebuilt head.
My truck is a daily driver. So consider what you are going to be doing with it.
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
I must stand corrected. I should read before I reply. I was under the assumption that the early trucks had a powerglide option. I did not realize the hydramatic was offered in the early trucks.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I think I replied to the wrong post. Guess I shouldn't have more than one window open at a time.
"The Fake Truck"
