| | | Forums66 Topics128,192 Posts1,057,355 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81051 08/05/2007 5:39 AM | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | I need some help/advice on fixing an oil leak that appears to be coming from the mainfold or cylinder head.
The entire left rear of the block is wet with oil - not fuel. It starts just under the intake/exhaust manifolds and runs down the block.
My first thought was to change the head gasket, but I'd like to see if anyone had any ideas or had seen this before. Compression is even across all cylinders and I'm not burning an excessive amount of oil.
Anyone seen this before or have any ideas or guidance? Thanks! | | |
#81052 08/05/2007 4:51 PM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | First, check the valve cover gasket. | | |
#81053 08/06/2007 2:33 AM | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | Done. The head is clean all around (even in the back). The leak seems to be coming from in between the bottom of the head and the block - where the gasket is. This seems strange to me, as I didn't think there was any oil circulating near there.
Maybe it's just a bad head gasket, but it just seems strange to have a leak in that area... | | |
#81054 08/06/2007 2:54 AM | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | Would there be a fitting connection in that area for the oil filter? Just a guess.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
#81055 08/08/2007 9:29 PM | Joined: Nov 2005 Posts: 13 New Guy | | New Guy Joined: Nov 2005 Posts: 13 | No, no fittings in that area. Just oil leaking down the side of the block.
Thanks for the reply. | | |
#81056 08/09/2007 5:16 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | This sounds like bad news. You may have a cracked block. Without looking at it, this is a guess. Cecil........ | | |
