1 members (TrknGMC),
31
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Ok so the first project I did on my truck was the brake system and they have been great for 4 years. The other day I took the truck for a ride and the brakes were soft. I checked the fluid and there was none in the master....
There appears to be a very tiny leak in the front of the master. Not even enough to drip on the floor (I have never seen any evidence of leaking until I peel back the rubber boot). When depressing the brake there is a tiny weep at the front of the master.
All brake parts are new (4 years ago)
Should I have been checking the brake fluid routinely? Is is usual to have this type of leak?
Thanks Rich
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I check in the spring when I take the truck out frist time and every 6 to 8 weeks after that tell winter,but I do that to my other truck and my wifes car also.Best be safe.
Pete | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | These old trucks ain't got very good brakes compared to newer vehicles. Keep 'em adjusted and check that master cylinder often. Your truck will thank you !! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes you should be checking it routinely, and checking adjustment as well, and now that you've found the master reservoir empty it's time to bleed the system, these old systems are vented to the air - unchecked for 4 years, the fluid loss is as likely to have been from evaporation as from a weep that's so minor it isn't evident outside the rubber boot
Bill | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Thanks Guys...I will check monthly from now on.
I will need to bleed and adjust before I take her out of storage in the spring. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | Just a little tip. I have rebuilt hundreds of brake cyls with good results,but in working on firetrucks I had poor results in rebuilding them.My thoughts are when you over bore the cyl and it sets for long periods the pressure drops off and allows the cup to relax thus it leaks. To verify this I would go by the fire house every week or so and pump the brakes. As long as I did this they would not leak.Just more stuff based on real world expierence. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have fluid leaking out the boot, the scraper piston that retains the fluid is leaking. You need to pull the master and redo it. You can keep adding fluid but you may pay for it some day. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes without a doubt check all the fluids in any machine routinely. That is one of the ten commandments of machinery maintenance (don't ask me what the other 9 are) | | | | | Joined: Apr 2005 Posts: 17 New Guy | | New Guy Joined: Apr 2005 Posts: 17 | just one quick question; does anybody change brake fluid anymore??? after months/years of absorbing water it turns to crap......kev | | |
