| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Im trying to take the side panels off my 1953 shortbed. I see the front is bolted in on either side by a few bolts. and the cross braces are held in by a bolt on each end. Is the back cross member just held in by 3 or 4 bolts on either side? Mine looks like it might be welded as well? | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Yes, the bed is probably welded where the side panels meet the back side of the rear cross brace. Sometimes if the bed has been apart it will already be cut.
It's normally not very much and can be cut with a thin cutoff wheel in 4" angle grinder. Don't go very deep, just enough to cut through the weld bead.
Paul | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | | | |
