Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rnl364, baldeagle), 63 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#809076 12/21/2011 6:56 PM
Is there such a process that can give you the brushed aluminum look ? Can it be done like chrome or powder coating on any metal ?
There is a paint I have seenthat looks ok on a wall, I don't know about heat resistance. I just went with power coat on the stuff I needed cleaned up.
You can nickel plate and hit it with a fine skotch bright pad in one direction.. should look good
This may not answer your question as asked but may be helpful in the future. I discovered a chromer in the Balch Springs area of Dallas who does a very good job and is incredibly inexpensive. These two parts cost me only $10 each.
He has been in business for 19 years and has a big-time shop with 7,000 gal tanks.
Chrome hood 3600's
~Jim
If it is already chromed you can spray it with WD40 and use a scotch bright pad on it. I've done a couple tests on some spare chrome parts and it gives you a nice brushed aluminum affect.
[Linked Image from i1188.photobucket.com]
What size of piece? you could use a drill press and engine turn it.
If your question was directed at me, the two pieces (3600) are 4" X 2".
~Jim
