Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#808339 12/19/2011 4:41 PM
Hello All -
What are the common culprits if an engine overheats? My red idiot light comes on on occassion. I'm hoping it's as easy as a thermostat.
Thanks!
Thom Masterson
Bats62Chevy #808340 12/19/2011 4:52 PM
thermostat
coolant level
loose fan belt
clogged coolant passages in engine
bad radiator
clogged/collapsed hose(s)
bad water pump
something wrong with engine - head gasket leak
clogged exhaust system
bad temperature sensor
engine timing is off?
lean carburetor setting?
http://www.aa1car.com/library/overheat.htm
http://www.troubleshooters.com/toverheat.htm
Under what conditions does the light come on?
Bats62Chevy #808341 12/19/2011 4:54 PM
The thermostat usually goes and it gets really hot, never seen one have an intermittent problem. More likely the radiator has internal blockage or a weak hose is collapsing. If you haven't already, flushing the system might do it some good.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
And then it could be just a bad sensor.............
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
johntsmith #808442 12/19/2011 10:36 PM
The sensor is new. If it's a thermostat, which one do I buy? There are different temperature ratings on each thermostat. I have a 235.
Also, I will flush my system (the truck...not mine) and see if that helps.
Thanks!
Thom Masterson
Bats62Chevy #808658 12/20/2011 1:58 PM
I would think that a 180 would work, maybe a 190 if you live in a real cold area.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
