| | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Hello All - What are the common culprits if an engine overheats? My red idiot light comes on on occassion. I'm hoping it's as easy as a thermostat. Thanks!
Thom Masterson
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The thermostat usually goes and it gets really hot, never seen one have an intermittent problem. More likely the radiator has internal blockage or a weak hose is collapsing. If you haven't already, flushing the system might do it some good. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | And then it could be just a bad sensor.............
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | The sensor is new. If it's a thermostat, which one do I buy? There are different temperature ratings on each thermostat. I have a 235. Also, I will flush my system (the truck...not mine) and see if that helps. Thanks!
Thom Masterson
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I would think that a 180 would work, maybe a 190 if you live in a real cold area. | | |
