3 members (2-Ton, Danielbolt, Otto Skorzeny), 106 guests, and 3 robots.
Topics128,100
Posts1,056,510
Members48,448
#807607 12/17/2011 6:05 AM
So, I've noticed that I have a starboard list on my panel after I fill it with gas. I suppose the spring has sagged under the tremendous torque the mighty 235 makes! Or years of toting gas around, or both. She leans over more than an inch. Perhaps I should have a kick stand instead of curb feelers.
Any body else have a list on their Panel or Suburban?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
ODSS President
ODSS President
Cab mounts sagging from rust?
~ Cosmo
1949 Chevy Half Ton
Nah, the sag is in the back. The front is sagged evenly on both sides!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Sounds like you need new rear springs! Either re-arch them or replace them with new. The gas tank is on the right side and that may have been the cause of yours going south. If it sat for awhile with a full tank of gas, that could be the cause.
I highly recommend new springs all around. Replacing the springs on my burb made the most significant improvement in drivability of any one thing I have done in the almost 40 years that I have owned it.
I got my springs from SDTrucksprings.com
SDTrucksprings.com
Kurt
Yeah, I recall when you put those on your truck Kurt. That's on my someday in the next year or so list. I think that's a great idea.
I was just wondering if anyone else had the same list. I'm sure its from the truck sitting, either on a slope, or full of gas for 40 years, or full of junk!
This is the first half ton I've had, my other bolt was a 1 ton, and man those springs were stiff! This half ton sure rides smoother.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Y
Y Offline
I've been inspecting my latest addition a 53 burb, and found a number of items that can cause a vehicle to not set level? Leaking shocks, fatigued springs, worn spring bushings, worn spring eye bolts, and tires. Everything needs to be up to spec's.
...take a look and see if one of them is broken. It may not "manifest" itself until you get some weight on it.
Most likely the springs need re arched or replace with new ones.I purchased my springs from Classic Parts Of America and they are made in the USA !!!
Tim
1951 3100 Chevrolet
For now, I just keep my tool box on the port side. I'll add new, or re-arching to my eventual to-do list.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I would spend the $$ on re-arcing the springs.
Shocks only improve ride quality, they dont hold up any weight.
Of course, check the shackles and bushings,etc..
If your truck has the old knee-action shocks, you may want to change them out for the newer style tubular type. Youll get a much better ride and have more selections for replacement.
You can find fellow 'bolters that are parting out trucks, that will sell you the frame mounts for the newer style shocks.
Good Luck,
Marty
