run a search on universal exhaust system. I picked my set up from Summit racing, Speedway motors sells them to. I picked up the 2 1/4" pipes. I went and picked up 2 turbo mufflers from a local exhaust shop for $20.00 a piece and they opened the ends of the mufflers for me to slide over the pipes.. The universal exhaust kit ran me $182.oo. I picked up some hangers from Adavance auto. The whole set up ran me around $250.00. The universal kit comes with 4 stight lengths, 4 45s 4 80s and 4 U shape pipes. I had plenty to run and some left over. I used a 110 mig welder, but you can clamp the joints to. I used a 4 1/2" grinder with cut off wheels to cut my pipe when needed. It was real easy to do but it does take a little time. I used a black sharpie marker and maked where my pipes needed cutting. Just take your time first test fit the pipes to get a idea where they need to go. The mufflers shiopd around here wanted $340 + tax to do my dual exhaust set up. So you do save some money, plus you can say that you did it yourself.
