| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | I apologize in advance if I'm asking in the wrong place or if this has been covered (which I'm sure it has). I've searched and can not find any information. I have a 1950 3600, the serial number on the engine (stamped directly behind the dipstick) starts with MVD and than has a 6 digit number. I can not find what MVD is. The truck was built in LA in February 1950. Anyone have any ideas? Thank you,
Wayne S. Colorado Springs, CO
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Just a guess since no one else is responding to your question. This may be a state assigned number for a replacement engine. 'MVD' could stand for 'Motor Vehicle Division' followed by the rest of the state assigned number. If you can check and see what states it has been titled in you may be closer to an answer. Someone else may have a better answer.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are locations of other codes. Post what you find and people will help to ID the year/size of the engine. | | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | I went out last night looking for the other codes but could not find them. This engine appears to have about 50 years of grease and grime built on it so this weekend I will start cleaning the engine and see if I can find some more codes. Thanks for the help. I was hoping MVD meant something to someone, but it is probably Motor Vehicle Division. :-(
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Do you know the State origin of the number? If so you could contact the Motor Vehicle Div of that State and inquire how or if they did it & when. Might be helpful in tracking things down. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Do you know the State origin of the number? If so you could contact the Motor Vehicle Div of that State and inquire how or if they did it & when. Might be helpful in tracking things down. | | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | I am officially giving up on figuring this out. I scrubbed and cleaned, there are no markings where they are supposed to be. The serial number is quite clear (blurry last three numbers in the picture here, but actually very clear in real life picture. I even had a neighbor come over and look for the numbers. Nothing. I will assume it was a factory replacement engine?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I can tell by the side mount bosses it is a 1952-54 engine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | Thank you, I will just call it a 52 - 54 216 and I bet any parts I need to buy will probably fit just fine. :-) It has two bolts in the valve cover so it is most likely a 216 I think. engine picture
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216s were only made from 1937-53. Can you post a pic of the pass side of the engine?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 | Hi Pre '68 Dave - I've loaded 5 pics of the passenger side of the engine here . They should be the first 5 pictures you see. I am curious to see what you think and than understand why? Thanks for your help.
