| | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80713 08/01/2007 2:21 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | I all ready checked using the search but couldnt come up with the answer to this question. Should the oil filter fit snugly into the canister? The oil filter I have gotten from two sources both leave about a 1/2 inch between them and the canister when installed. I have a 58-62 from I believe a passenger car. The canister looks to have an orange lid with a light blue body. The old filter I pulled out fit perfectly. I am just not sure what size is the correct one! Thanks! | | |
#80714 08/01/2007 2:35 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | that will not do ...without a tight seal in the canister the filter will just float around an do nothing ...do ya have the one ya took out for measurement of length ? | | |
#80715 08/01/2007 3:28 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Purney,
We have several canister type oil and fuel filters on equipment at work. I don't thing the OD/ID relationship is critical...the filter is sealed at the top and the bottom of the can, this is what is important.
Stuart | | |
#80716 08/01/2007 6:19 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | The one I took out is 4 1/2 inches OD and 5 inches tall. The replacement that everyone is selling me is 4 inches OD and 5 inches tall. its the NAPA 1100 which should be correct but isnt.
Stuart, are you saying this will work as long as the filther height is correct and the cansister seals as it should? | | |
#80717 08/01/2007 7:04 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Purney,
If the cartridge seals properly at the top and bottom, all the incoming oil must pass through the filter before it gets back into the system. Why you can't find a cartridge the same size as the old one I don't know. A smaller cartridge would mean less square inches of filter material, but as long as it seals top and bottom, it should work. Hope I'm not all wet on this!
Stuart | | |
#80718 08/01/2007 7:44 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | I found a thread on here where someone had the exact same issue but no one had the answer then either on the OD issue. If I had no bad luck I wouldnt have any luck at all! | | |
#80719 08/01/2007 9:33 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | One post indicated that the extra clearance helped oil flow by being less restrictive. I don't know if that is actually true. | | |
#80720 08/01/2007 9:54 PM | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Sounds like the same size as my Fram C4P filter element. It's NAPA equivalent is #1006
1948 AD Pickup
#80721 08/01/2007 10:16 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Interesting thing, at the NAPA store and on thier web site, the dimensions of the filter #1100 is 4.5 inches OD. Their book at the store said the same. However out of the box it is not 4.5 inches it is only 4. I had the counter guy call another store just to see if they put the wrong one in and it was 4 inches as well! I give up. | | |
#80722 08/01/2007 10:24 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Purney,
Wix has a great cross reference site. I went there and input a bunch of your numbers and numbers from previous posts. They indicate that many of the filter cartridges mentioned are 4.094 OD X 5.007 high. The number littlebuddie just quoted comes right back to those dimensions. I think the filter numbering system has been around for so long that it is funked up. The same filter might have two different numbers for two different applications...I'll throw in the towel too!
Stuart | | |
#80723 08/01/2007 10:46 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | I have a wix 51100 straight from Classic parts that has the same problem. I sent an email to NAPA requesting some clarification. If I get an answer, Ill post it. Till then, I am installing the one I got. Thanks all! | | |
#80724 08/01/2007 11:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There were 2 different filters used on the old stovebolts. The factery or dealer installed was AC brand. It uses a 5/8" wrench on the cover bolt. The popular aftermarket filter was Fram. It uses a 7/8 in wrench on the cover bolt. They use different filters. Make shure they are supplying the right filter. The fram # is C4 like L buddie mentioned. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#80725 08/02/2007 2:03 AM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | As long as the height is correct, 1/2" difference in diameter won't make enough difference in the filtration to matter. The important specification is the micron measurement of the holes in the paper filtering media. Bypass filters like the old stovebolt units can have VERY fine micron numbers, because the oil does not have to flow through the filter with enough volume to lubricate the engine. An average full flow filter has about 2 or 3 micron holes, indicating particles smaller than 2 or 3 thousandths of an inch will pass through the filter and stay in circulation.
The Frantz bypass filters I used to sell for 18 wheelers fit the LuberFiner 750 canisters, and were rolled out of toilet tissue. They were 1/10 micron rated, which meant they would filter out particles as small as 1/10,000 inch. These filters were not intended to be full-flow capable, but they would clean even the tiniest dirt particles out of the oil. We ran 10,000 miles between filter changes, and never changed the oil. On a 15-gallon system, it usually required 2 gallons to be added during a filter change to replace what was trapped in the cartridge. We had several engines with well over 100,000 miles on the oil, and it still passed spectrometric analysis of the oil samples we took during filter changes. Jerry
#80726 08/02/2007 4:17 AM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Great info guys, its a 5/8 inch bolt, orange lid, blue body, looks to be AC. Who would have thunk an oil filter would have stumped me??? | | |
