4 members (Shaffer's1950, cmayna, 2 invisible), 122 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
Does anyone know if my 65 gmc stepside would have had somekind of undercoating in the wheel wells, and on the undercarage? it seems almost like a mix of baked on tar and dirt.
My '65 Chevy Stepside has some type of undercoating, and a good mix of asphalt and mud too.
The rear fender support rods that go behind the tires are caked with asphalt and mud... I cleaned one and noticed it was in great shape, therefore left the others alone.
I remember several shops would put a vehicle up on the lift and spray undercoating on them. Since it was new there is no telling what has been done unless you can establish an owners trail.
When I pulled the front fenders off my '59, I noticed this undercoating all inside and on the back of my headlight buckets.
To get to some of the bolts to remove the fender, I had to gouge and scrape away this hardened tar mixture... but the bolts were shiney as new underneath... cool.
