1 members (RLB),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I understand that Stromberg made an aftermarket carb for the 235. Was curious if anyone has tried one, and what model of Stromberg (identifying numbers) would this be?
Kurt | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The most popular Stromberg for dual carbs was the BXOV-2 (14-22 stamped on top) which actually was a replacement on a 216. I do not have a Stromberg listing but they made repacements for everything. Try searching Stombergs on line, I know I've seen a copy online in the past. I like the modern rebuilt carbs from Langdon's stovebolt, Holley-Webers and Carters. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Here is a listing of the model breakdown: http://www.thecarburetorshop.com/Strombergcodebreakdown.htmThe code Stromberg used for Chevrolet was 14. I think I once posted a list of the numbers Stromberg used for Chevrolet, but cannot seem to find it. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Thanks Jon,
This will help in the search for one of these carbs. I'm looking for a Stromberg or Carter to replace the Rochester on my 235 as I understand they are better carburetors.
Do you have any suggestions for other alternatives for the 235?
Kurt | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | If memory serves me, Holley 94 comes to mind. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I think the holly 94 was a ford carburetor?
Kurt | | |
