1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#805805 12/11/2011 7:30 PM
My engime cranks and starts fine in the warmer weather, but during winter the battery dies before the engine turns over and then I drag out the charger and it will recharge and crank fine. What can I do to get it to turn over sooner?
Thos is a 216 cu in 6 v floor starter set up I am using. Thanks
Are you using full choke as soon as you start cranking? These old engines are pretty cold-natured. If the fuel level in the carburetor is right and the ignition is well-tuned, it should start in the first 5 seconds or so of cranking with the choke pulled out all the way. If the engine won't crank for 30 seconds at normal cranking speed without a boost, you need a new battery, or the cable connections and grounds are bad.
Jerry's advice, as usual, is the first thing to consider.
Here is another thread about hard-starting. There are several additional factors to consider. Hard starting 6v systems are a common occurrence, if something is not up-to-snuff.
Thanks Jerry. I will use the choke and see how that plays in my situation. I have never driven a vehicle this old, or a 6v system either. Maybe that is why I have kept it like the factory made it. I has brand new ground straps and a new battery. Cant wait for tomorrow so I can try the choke.
I drove around the block with it today a few times for the first time since I purchased it. I installed the transmission that I just got a couple weeks ago
I pulled the choke out before I pushed the floor starter and it started right up. Thanks.
Good show! That's why I like automatic chokes- - - - -they're smarter than all drivers, and most mechanics! With a properly-set automatic choke and fast idle system, just tap the throttle once to allow it to preset itself, and crank the engine without touching the gas pedal. It will start and set itself to the most effective warmup RPM without any input from the driver at all. Correct cold starting with a manual choke is definitely a learned skill.
Ignorance can be fixed............
