8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | My engime cranks and starts fine in the warmer weather, but during winter the battery dies before the engine turns over and then I drag out the charger and it will recharge and crank fine. What can I do to get it to turn over sooner?
Thos is a 216 cu in 6 v floor starter set up I am using. Thanks | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Are you using full choke as soon as you start cranking? These old engines are pretty cold-natured. If the fuel level in the carburetor is right and the ignition is well-tuned, it should start in the first 5 seconds or so of cranking with the choke pulled out all the way. If the engine won't crank for 30 seconds at normal cranking speed without a boost, you need a new battery, or the cable connections and grounds are bad. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jerry's advice, as usual, is the first thing to consider. Here is another thread about hard-starting. There are several additional factors to consider. Hard starting 6v systems are a common occurrence, if something is not up-to-snuff. | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | Thanks Jerry. I will use the choke and see how that plays in my situation. I have never driven a vehicle this old, or a 6v system either. Maybe that is why I have kept it like the factory made it. I has brand new ground straps and a new battery. Cant wait for tomorrow so I can try the choke.
I drove around the block with it today a few times for the first time since I purchased it. I installed the transmission that I just got a couple weeks ago | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I pulled the choke out before I pushed the floor starter and it started right up. Thanks. | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Good show! That's why I like automatic chokes- - - - -they're smarter than all drivers, and most mechanics! With a properly-set automatic choke and fast idle system, just tap the throttle once to allow it to preset itself, and crank the engine without touching the gas pedal. It will start and set itself to the most effective warmup RPM without any input from the driver at all. Correct cold starting with a manual choke is definitely a learned skill. Jerry
| | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | Ignorance can be fixed............ | | |
