| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | My glove box cover latch bracket is broken, I was wondering if any of you could give me the shape, size any specks on that latch bracket. the cover is in good shape and hate to buy another just because latch is broken. I plan on fabricating part and welding on. Any help would be greatly apprciated. | | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | I see 69 of you have read my delema. All I need is for someone to take a profile picture of the bracket with dimensions where bends are and size of square hole where lock latches. Otherwise I will have to make bracket in the dark. The glove box doors cost too much and they don't sell the bracket alone due to spot welded to inside panel. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Are you talking about the catch that was spot welded to the glove box door?
Mine broke so I took a big heavy duty washer and bent it. After grinding it down a bit, I used sheet metal screws to attached it to the door. Of course, my truck isn't a restoration.
I have a pic on another computer and will post it when I can.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Wally / Montana : that's some good thinkin' right there.
-W | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Wow, nice fab work Denny.  -W | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just tryin' to keep it original Woo. dg
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | DG, I see the bends from the one sheet on the print... but how did ya make the cut for the tab? Just trying to learn something new.  -W | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The material is only 1/16", I cut thru the three sides with a freshly sharpened 3/8" chisel then drove it out with a square punch. Once the tab was separated on the three side I formed the main curve around a piece of round stock and used a smaller piece to form the tighter radius on the tab. I copied it from a spare door that had the original factory spot welded latch still on it. My door was in good shape except for the latch being broken off. The spare door had a bad crease across the front and there is no way to pull it out since the front and back are spot welded together. I tacked the latch to the door with the TIG then made a couple of minor adjustments after installing it. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | neat.
Thanks for the explanation.
That's good tech there.
-W | | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | Wally / Montana that was a very good idea seems like it would work!
Denny Graham I love your drawing and picture looks original I guess? I don't have one to compare with. Thank you so much with the detailed drawing and explanation of how you curved the latch catch. I'm a cadd designer and a drawing is perfect wasn't expecting that detail. Seems like alot of AD truck owners have this broken latch problem.
Thank you guys so much for the info. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That should look just like the original one as I said, I copied it off of an original door that was bent. I taint no draftsman but I do like to sketch up what ever I take off or need to make for the trucks so if it ever pops up again I have the dimensions on file. My daughter is pretty good at AutoCAD and keeps buggin’ me to use it. But I've tried using it since it was first released. I worked in the inspection group and we had a seat on the mainframe where I worked which we used in programming the CMM machines, the nd we had a seat on it for our inspection group. But the learning curve is to steep for me, since I’m just a part time user. If I'm away from it for a few weeks or a month I have to start all over leaning how to use it again and never get any thing done. I started using Design Cad 3-D back about twenty some years ago when I got my 386SX and have used it in the 2-D mode ever since to make up the working sketches for the shop. I can be away from it for six months and I'm back making a usable drawing in 5 or 10 minutes.
| | | | | Joined: Sep 2011 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 46 | Well Denny, I thamk you for keeping up your 2D skills. I pulled your file and saved it on my computer,so when I get the chance to make the latch. I had to pull the stainless skin off due to rust particles rattling inside. Which might be a good thing because I don't want to arc the stainless skin when I weld on new bracket. I whished I had pro-e (which is what I use at work) on my home computer, but it would cost me 30,000 to get license. I can't seem to convince my company to give me the license. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That used to be the problem with AutoCAD, it was about 20K and about 5K for each aditional seat. Since my daughter was a design student and we got a student copy thru the collage, which was very affordable for home use. But, all I needed was a pencil, paper and a tri-square for my type of work in the shop and my simple Design CAD program is just that.
Hope you have a happy and prosperous New Year.
