3 members (FishinToms53, joe apple, Hotrod Lincoln), 81 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
1 Offline
ive got a 1951 panel that we use for deliveries here in vegas and am going to pull the small block out and install a 5.9 cummins out of a dodge pickup allready have the adapters for the 700r4 i have in it now will up date more when this one gets started as i have a 6400 im doing also and have to wait till its done to tear this one apart
very interesting project! Should be a cruiser for sure. smile Please post pics when you get a chance. Oh, and I see you are fairly new to the 'bolt. Welcome!! wave There's lots of great people and info in here. Looking forward to hearing more, and yeah, seeing the pics.
That transmission is going to need some help.
H Online: Content
You'll need to do some major beefing-up on the front suspension to carry the weight of the Cummins engine, and the transmission will need to be built up to Corvette specifications, including changing to the deep-capacity overdrive clutch drum to handle the torque of that engine.
here in manteca there is a highly modified 34 f/// pickup with a cumming eng&allison trans.nothing stock on the truck,everything is custom built...
You should also join this forum if you haven't already.
http://www.4btswaps.com
The best site for Diesel conversion info of all makes and brands.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
1 Offline
trans was built before it was installed with this in mind it currently has a 400 small block in it now and its only a 160 horse 5.9 with no plans to mod it as once this truck is completed it is going to washington dc when we open up our new store
