| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 3 New Guy | | New Guy Joined: Dec 2011 Posts: 3 | ive got a 1951 panel that we use for deliveries here in vegas and am going to pull the small block out and install a 5.9 cummins out of a dodge pickup allready have the adapters for the 700r4 i have in it now will up date more when this one gets started as i have a 6400 im doing also and have to wait till its done to tear this one apart | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | very interesting project! Should be a cruiser for sure.  Please post pics when you get a chance. Oh, and I see you are fairly new to the 'bolt. Welcome!!  There's lots of great people and info in here. Looking forward to hearing more, and yeah, seeing the pics. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | That transmission is going to need some help. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | You'll need to do some major beefing-up on the front suspension to carry the weight of the Cummins engine, and the transmission will need to be built up to Corvette specifications, including changing to the deep-capacity overdrive clutch drum to handle the torque of that engine. Jerry
| | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | here in manteca there is a highly modified 34 f/// pickup with a cumming eng&allison trans.nothing stock on the truck,everything is custom built... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You should also join this forum if you haven't already. http://www.4btswaps.comThe best site for Diesel conversion info of all makes and brands. Grigg | | | | | Joined: Dec 2011 Posts: 3 New Guy | | New Guy Joined: Dec 2011 Posts: 3 | trans was built before it was installed with this in mind it currently has a 400 small block in it now and its only a 160 horse 5.9 with no plans to mod it as once this truck is completed it is going to washington dc when we open up our new store | | |
