1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I remember reading somewhere on the 'Bolt that the front fenders on larger trucks are bigger than the front fenders on 1/2, 3/4, 1 ton trucks.
Is this so, and if so, what dimensions are bigger?
I went to the local salvage yard and they look the same to my eye.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Jul 2004 Posts: 2,993 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,993 | Not sure what else, but I know the wheel wells are bigger. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chevoldsmoyota, as Rich'sToys said the wheel opening is larger, and the fenders are wider, the hoods on the larger trucks are also different where the hood meets the fender/cowl, hope that helps. | | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | They are taller too. Well at least 47 though 54 is. Where the grill mounts to the fenders in front is about 2in taller. The grill is also 2 inches taller than the smaller trucks. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I have made my 3800 into a 4-wheel drive and the front axle is wider than stock. I was hoping to use a wider fender to cover the tires better, but it sounds like I'd have to replace inner fenders, hood and grille too. . .more than I bargained for.
Thanks for all the replies, guys!
Craig
CK
| | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | Yea I don't think the big trucks fenders are much if any wider, mainly taller with bigger wheel wells I know for a fact the grill is the same width cause I got half-ton splash bars in my 2 ton, but I had to change the vertical posts to make it tall enough. If your good at body work you can cut the fenders and make them wider. I've seen guys do this before, take a look in the gallery, I think that's where I saw it. | | |
