6 members (Hotrod Lincoln, Gdads51, 2-Ton, Bill Hanlon, latroca52, Goach2), 131 guests, and 2 robots.
Topics128,204
Posts1,057,310
Members48,467
Hello -
Here's a pic of a T5 transmission I found, but I've never seen the drive before, so is this one an electronic drive or a cable drive?
(got my fingers crossed for cable).
Thanks...
Chris
http://i904.photobucket.com/albums/ac248/barsteel/DSC00943.jpg
Did you know that they now make a speedometer that runs off a GPS signal? Just thought you might want to know about that.
1951 1 Ton Completed
It looks like the one on the T-5 I pulled. It's a cable drive adapter. If you look closely you'll probably find a number on it which matches the OD ratio of the transmission. My guess it's used to adapt an OD transmission into a vehicle with a speedometer calibrated for a non-OD transmission. I removed the one on mine since I still have the original rear gear. Following my wife in a Yukon my speedo reading appears to be correct.
Harold Wilson
41 Chevy 3/4 Ton
Harold -
So based on what you're saying, this is a mechanical drive speedometer cable with a plug-in adaptor?
Chris
Yes. The adapter has a threaded nut just like the one on the end of the speedo cable. That's how it's attached to the transmission.
Harold Wilson
41 Chevy 3/4 Ton
Yep,it's a mechanical speedometer transmission.
Clean the top off,there should be a sticker decal with the model number.They start out with 1352-???.See this link for Identification. T5 Identification
your electrical plug will be for reverse lights.
Tim
1951 3100 Chevrolet
There is a stamped ratio # on it. Anything above 1.0 will increse speedometer, less will slow it down. i.e. a adapter stamped 0.97 will slow the indicated speed down 3%
BC
BC
1960 C60 pasture art
It seems to me that you are saying that it is nothing more than an external correction device for tire size. I have seen those around. Is this correct?
Les
