2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello - Here's a pic of a T5 transmission I found, but I've never seen the drive before, so is this one an electronic drive or a cable drive? (got my fingers crossed for cable). Thanks... Chris http://i904.photobucket.com/albums/ac248/barsteel/DSC00943.jpg | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Did you know that they now make a speedometer that runs off a GPS signal? Just thought you might want to know about that. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | It looks like the one on the T-5 I pulled. It's a cable drive adapter. If you look closely you'll probably find a number on it which matches the OD ratio of the transmission. My guess it's used to adapt an OD transmission into a vehicle with a speedometer calibrated for a non-OD transmission. I removed the one on mine since I still have the original rear gear. Following my wife in a Yukon my speedo reading appears to be correct.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Harold -
So based on what you're saying, this is a mechanical drive speedometer cable with a plug-in adaptor?
Chris | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Yes. The adapter has a threaded nut just like the one on the end of the speedo cable. That's how it's attached to the transmission.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yep,it's a mechanical speedometer transmission. Clean the top off,there should be a sticker decal with the model number.They start out with 1352-???.See this link for Identification. T5 Identification your electrical plug will be for reverse lights. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2011 Posts: 1,461 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,461 | There is a stamped ratio # on it. Anything above 1.0 will increse speedometer, less will slow it down. i.e. a adapter stamped 0.97 will slow the indicated speed down 3% BC
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | It seems to me that you are saying that it is nothing more than an external correction device for tire size. I have seen those around. Is this correct?
Les | | |
