2 members (kades51, tclederman),
106
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | So after spending a good amount of money on building this 261, I'm thinking I should replace the head, main and flywheel bolts. What are others using? I just looked at the ARP catalog. Almost everything they have listed is for the 250 series blocks, not the 235,261. I can order studs, which I might do, for the head. I'm just curious what others are doing.
Jeremy | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Try Chevies of the 40's and McMaster Carr. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | I started working on these things when Christ was a corporal and never replaced the bolts and never had a bolt failure. Make sure the threads are clean and they are properly torqued,youll be OK. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I second the above motion. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | well if you do decide to get new bolts, ARP doesn't have a full complement of bolts that will fit in all the locations, they do however have studs that will work. ARP was the best company to work with I have ever seen. | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | I went with the bolts I had. When I realized this engine will NEVER see 6000 rpm I made my decision. I used to build High output 5 cylinder turbo powered engines.. I guess old habits die hard.
Now when I build a six with Fuel Injection, Electronic Ignition, Turbo, yeah ... then I'll call ARP.
@brokenhead- yeah they are always simple to deal with. Jeremy | | |
