2 members (moparguy, DadsFirstPickup), 75 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
So after spending a good amount of money on building this 261, I'm thinking I should replace the head, main and flywheel bolts.
What are others using?
I just looked at the ARP catalog. Almost everything they have listed is for the 250 series blocks, not the 235,261.
I can order studs, which I might do, for the head.
I'm just curious what others are doing.
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
Try Chevies of the 40's and McMaster Carr.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I started working on these things when Christ was a corporal and never replaced the bolts and never had a bolt failure. Make sure the threads are clean and they are properly torqued,youll be OK.
I second the above motion.
1951 1 Ton Completed
Amen
well if you do decide to get new bolts, ARP doesn't have a full complement of bolts that will fit in all the locations, they do however have studs that will work. ARP was the best company to work with I have ever seen.
I went with the bolts I had.
When I realized this engine will NEVER see 6000 rpm I made my decision.
I used to build High output 5 cylinder turbo powered engines.. I guess old habits die hard.
Now when I build a six with Fuel Injection, Electronic Ignition, Turbo, yeah ... then I'll call ARP.
@brokenhead- yeah they are always simple to deal with.
Jeremy
More pix on Flickr
