2 members (klhansen, 59 fleet),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | New guy with lots of questions. No oil filter? After searching for a while, I see I may not have an oil filter. Thought I was going crazy/blind. Do ya'll retro fit one in. if so how/where/what? Oil bath cleaner....worth keeping, or swap it out, again if so, how/where/what? How much oil for an oil change? Don't have a book yet, but anxious to start firing her off. Plenty more questions coming, but that's a good start. Thanks ya'll. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if it was a 235. it was optional. they were an accessory item ron | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | The oil bath air cleaner sucks a lot of oil fumes through the carb and gives off a lot of emissions. Found this out when I brought the 64 GMC for an Emissions check. We emptied the air cleaner of oil and the truck passed. I then modified the stock air cleaner and installed a paper element. I always carried spare oil for the crankcase when I had my 62 K10. The shop manual you need is from 1960 and you need the 62 Supplement to show you the few differences between those years. Never should have given it away! The accessory remote oil filter bolts to the intake manifold and the lines run into the block I believe. Never had one on my truck just change the oil frenquently. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | Very nice. So you're keeping the oil bath cleaner. And I see the oil filter location there. Thanks. I drained the oil, added 4 qts, shows half a qt. low. Haven't got it started yet. Turns nicely, but not getting spark. I changed plugs, gapped .035, new coil. P.O. had dist cpa off, looks to be a new condensor and points in there, but getting no spark. I pulled #1 wire, stuck a plug in and ground to block while kids turn the key, nothing. Tried the next plug wire, still nothing. Guess I'll run to town and get a new contact set and condensor? | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Do you have juice going to the coil?? | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | It's alive!!!Replaced points and condensor, shot starter fluid down carb, turn key, fired right up.Needs a fuel pump and carb rebuilt. Starter fluid comes out the bottom of carb. Gettin there.I guess i should start a project thread here somewhere? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | If you have that much starter fluid in there that it is running out the base of the carb, I think that you should let it evaporate before you go to start it. you don't need much, just a sniff of it is usually all that it takes, or you could be changing more than the fuel pump. ron | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | It was just a squirt...I think the gaskets are all just shot. Might have even been some gas in it if fuel pump is working. Pumped the tank out and put in some new gas. It will run a bit feathering the pedal, but I don't like the look of the carb or fuel pump, ordered a rebuild kit for the carb and a fuel pump this afternoon. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | have any pics of this truck? | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | Pics, yes. I thought I put them here. Maybe that was in the welcome section. I guess I should put them here and call this the project thread? | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | gazim, I don't seem to have one. Maybe it takes a bit to show? | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | | | | | | Joined: Feb 2011 Posts: 22 New Guy | | New Guy Joined: Feb 2011 Posts: 22 | Like a bad penny, I turned back up. I traded the 62 K10 to a buddy not long after my last post. We are doing another trade, and the 62 is coming back to me. While my buddy had it, he did the following.... Removed steering column (and traded it), non-power steering gear box (traded it), original axles swapped (and gone), installed 1980 Blazer axles,and bolted in 80 Blazer power steering gearbox, but was unable to hook up/attach 80 Blazer column. I'll be having lots of questions on what to look for to swap in, and ideas on getting it going again. While I had it the first time, I cleaned out the gas tank and got it running, all lights work, gauges even work. I'll ask questions later, don't want too long of a reply here. thanks for looking...again. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Welcome to the forum...how about some pics? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Unfortunately, the appreciated-value of the truck with the original equipment, has decreased with the non-factory donor parts from the '80 Blazer.
I would put your focus on:
Start Steer Stop
After these areas are addressed, go to work on the rest. Good luck and do your best to bring her back to life. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Sounds like you need a minor carb tune-up (gaskets and needle valve) | | |
