| | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | i have a 54 five window that i put on a 79 gmc sierra 4wd frame. the engine and tranny were there with the 79. will a 235 bolt to the turbo 350 tranny or am i stuck with the newer v8?
People sleep peacefully in their beds at night because rough men stand ready to do violence on their behalf. -George Orwell
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 235 will not directly bolt to a TH350, but there are adapter plates available to allow them to work together. Stovebolt Engine Co. and Buffalo Enterprises both have them.
Bill Burmeister | | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | thank you for that i will look into it
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | a 250 or a 292 will bolt up direct, Scott | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Unless I’m missing something here, the first thing that pops into my mind is why in the world would you want to replace a V8 with a 235??? Originality certainly isn't your goal, you've already created a "Frankenstein truck" by using '54 sheet metal on a '79 frame so why not just leave all of the original '79 running gear in place. The V8 is a much better engine than a 235 and you're not going to fool anyone into thinking it's an original truck by bolting an under powered six cylinder up to an automatic transmission four-wheel drive chassis.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I'd agree. The added power drag of the 4wd gear is going to heavily tax the 235. If you want the engine bay to look "original" I'd build a modified 250 or 292 that will bolt on to the TH350 as mentioned above.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
