7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle), 105 guests, and 2 robots.
Topics128,179
Posts1,057,068
Members48,460
i have a 54 five window that i put on a 79 gmc sierra 4wd frame. the engine and tranny were there with the 79. will a 235 bolt to the turbo 350 tranny or am i stuck with the newer v8?
People sleep peacefully in their beds at night because rough men stand ready to do violence on their behalf.
-George Orwell
The 235 will not directly bolt to a TH350, but there are adapter plates available to allow them to work together. Stovebolt Engine Co. and Buffalo Enterprises both have them.
Bill Burmeister
thank you for that i will look into it
-George Orwell
a 250 or a 292 will bolt up direct,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Unless I’m missing something here, the first thing that pops into my mind is why in the
world would you want to replace a V8 with a 235??? Originality certainly isn't your goal,
you've already created a "Frankenstein truck" by using '54 sheet metal on a '79 frame so
why not just leave all of the original '79 running gear in place. The V8 is a much better
engine than a 235 and you're not going to fool anyone into thinking it's an original truck
by bolting an under powered six cylinder up to an automatic transmission four-wheel
drive chassis.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I'd agree. The added power drag of the 4wd gear is going to heavily tax the 235. If you want the engine bay to look "original" I'd build a modified 250 or 292 that will bolt on to the TH350 as mentioned above.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
